Some idiot appears to have cut out the cat, welded in some tubing, welded up the bunfs for the o2 sensors and left them dangling. How tf am I gonna fix this without spending a fortune? Generic cat and have a shop weld in a wye pipe and some bungs? That's all I can think of
The best thing is to swap in a first gen cummins to avoid ever needing a cat ever.
When logic says that's not reasonable, maybe some magnaflow aftermarkets. though you may want to just take it to a shop and replace more than a few feet of pipe on that while your at it.
1. Drink a beer.
2. Zip tie the loose wires to the frame.
3. Have another beer.
4. Order a scan gauge.
5. 3rd beer.
6. Install the scan gauge and ignore/clear the po420 codes.
Options will depend on local emissions regulations. I have no clue how this works in Honolulu, but here, you would need to weld in new cats and o2 bungs and make sure it clears all obd codes and ECU reads "ready" in all categories. Even if you don't do everything by the book or you don't have emissions regulations in your locale, I would still recommend putting cats in just to reduce the lawnmower stank and not fork up our air quality any worse than it already is.
You're acting like this is a surprise to you, did you not inspect the vehicle when you bought it? Or did a thief really weld in straight pipes for you?
1. Drink a beer.
5. 3rd beer.
Regardless, your easiest route is to put the 02’s in the header. Get rid of the PAIR. You can use a 95-97 coolant hard line, or just use a coolant hose to get around where the PAIR was. Harness is long enough to reach there. Should run like a top with no CEL.
If you want to do it ‘right’ it won’t be a few hundred. It’ll be be a few thousand. Those cats aren’t cheap.
He's a 95+
What I don't know is if you got the entire system if it would be usable from the exhaust manifold back and you plugged the o2 bugs and move the sensors
I don't think my harness is long enough. The connection is down by the resonator. But I can extend them a d see if a shop can weld in a cheap generic cat
