I would appreciate any help and will be cross posting in the clubhouse forum for MO.
I am currently traveling from MD to CO. I had an issue ~8months back [THREAD HERE] it was diagnosed as the MAF which was replaced with an OEM part. I have had no issues up until yesterday. I was on my 2nd day of trip and after driving ~4 hours I pulled off the highway to get gas. I stopped at light and when I went to accelerate I had sudden loss of power, truck would not move and stalled when I fully pressed on accelerator. I did the same routine as previous, disconnected battery & cleaned MAF. It started back up and I made it into parking lot. I HAVE a spare MAF which I installed. Drove another 30min, went to pull into parking lot and same issue (with new MAF). * I did not get a CEL either time but when I checked pending codes I got P0174.
I am deciding if I should try to make it the rest of the way to CO or stay in MO and try to find someone to look at. Any help is greatly appreciated.
Summary of what has happened and what I noticed:
Prior to issue:
- Fluctuating idle around 65mph: I had thought this was a shifting issue b/c of tire size. If i pressed on gas it would downshift and fluctuation went away.
- Had some shaking while on highway. I thought maybe I lost a tire weight. I pulled over and checked, everything looked okay. Got back on highway and it was fine. (Did not turn truck off)
What has got me going again:
- With original MAF (8 months old). Disconnected battery & sprayed MAF. (did not wait 10min) [Drive into parking lot]
- Replaced original MAF with spare. Disconnected battery, waited ~10 min [Drove ~30min]
- Bought another MAF, disconnected battery for 10. [Have driven 45min with no problems]
I just measured all the MAFs.
OEM (8 month old) - 1.9kohms
Advance Auto Replacement (8 month old spare) - 2.0kohms
New Advance auto (new) - 2.0kohms
I have the manual (see below for what I have done). I want to know what I can eliminate based on the fact that when I disconnect battery I am able to get it up and running again?????? Also note its extremely hot outside while I am driving ~95-100f
I have gone through the manual diagnostics and it says to check the following:
air induction system [
injector blockage
MAF [Checked Res okay, cannot measure voltage]
Engine coolant sensor
Fuel Pressure
Gas Leak in exhaust system
Open or Short in O2 sensor
Heated O2 sensor?
Heated O2 sensor heater
EFI or ECD relay
PCV piping
ECM
Thanks in advance for any help
Prior to issue:
injector blockage
Fuel Pressure
Heated O2 sensor?
EFI or ECD relay
PCV piping
ECM
