In addition to the 5L stroker kit they have a few flavors of cams for the 1FZ-FE as well just no info on the BC web site.
BRIAN CROWER/ Cams TOYOTA/LEXUS 1FZFE STAGE2 264spec - eBay (item 250740384864 end time Jan-08-11 15:09:01 PST)
STROKER KITS
The Toyota Landcruiser 1FZFE stroker kit from Brian Crower features:
• BC 4340 billet steel crankshaft (101mm stroke).
• 4340 steel billet, custom Pro Series connecting rods w/ARP 220,000 psi fasteners.
• CP aluminum forged pistons (any bore size, any compression ratio).
• 9310 nickel carbon steel alloy wrist pins.
• Ductile iron plasma top rings, tapered second ring, low tension oil rings.
• ACL Race Series rod and main bearings sold separately.
• Fully system balanced and ready to install.
The BC stroker kit for the Toyota LandCruiser 1FZFE engine platform
incorporates a 101mm stroke, steel billet crank. Depending on bore
size that you decide, the BC kit will take you up to a 5.0L with 102mm
bore. As usual, each BC kit features custom CP aluminum forged pistons,
9310 alloy wrist pins, ring pack and buttons. Available in any desired bore
and compression ratio for use in turbo or normally aspirated.
BC Stroker Specifications:
5.00L 102mm Bore x 101mm Stroke (choice of bore and minimum compression of 9:1 to 14:1)
