Wanted Stock Rear Fj60/62 Springs
I might be able to help you out...are you set on OEM, cause I know where there is a pair of AM +2" lift springs in decent shape. I was thinking about putting the lift springs under my rig which currently runs a set of OEM with an OME add a leaf, but haven't decided which way to go yet...These are in Fresno. LMK
Yeah, need stock springs. They are going to go up front on my Fj60 which is already sprung over. The previous owner put it on OME 4" lift springs and SOA, so it is way to big.
well, if I put the AM springs under mine, I'll have my set available. they're flat enough if you remove the AAL from the packs. I'll let you know if I decide to pull the trigger.
I have springs but I'm in Idaho. Know anyone going to Cruise Moab? Also, you won't want to run just stock springs SOA. You'll want a long add a leaf or some other way of beefing them up a bit. They tend to crack if you run just stock springs without beefing them up.
Man, every pair that comes up so far away. Sorry don't know anyone going out there and thanks for the heads up on the add a leaf, haven't found a good write up on a build with RUFs yet.
I have a set of front springs and will have a complete set available later this year.
I have a pair in Seattle! Maybe someone can mud-ship them?
