SQOD Squad - Stupid Question Of the Day (12 Viewers)
Cant remember the name of the product but the commercial is a guy is in a boat with a screen door bottom that was treated with a spray on watertight / proof membrane. FIND THAT STUFF. Mask off your lights and spray the suspected leakage area with that product - might be a cheap fix.
I has a POS 07 Yukon Denali for about 6 months and both headlamps did that. I pulled the headlamp assemblies and used a hair dryer to get all the moisture out. Sprayed with soap and water at the seams while blowing air into the light housing. Once I found the bad sealer I just ran some clear silicone in those spots and it never came back.
The Yukon was put together so poorly, I could have the bumper cover and both lights off in 20 mins though.
Anybody know the price of a keyless remote? Upon purchasing my used 200, I was only given one. Would like to have another.
Not cheap. Guessing around $230 plus u must pay a dealership to program it...often another $90.
Only posting this so you can brace yourself for actual cost. It is up there in that range.
You are wise to get a second, though, because without ANY key? On my 100...that meant a HUGE cost due to need for replacing a larger vehicle component. Not sure if it's same for 200...
Thanks. I was prepared for the dealer bullsh#t. I lost both of mine with my 4Runner. What a PITA and very expensive.
I would definitely do it, as I believe they REQUIRE an existing key in order to program the new one.
Guys, need some help locating a replacement part for my 2011 LC roof rail rain guard. Getting my Gobi Stealth installed and learned that the driver side rail cap is missing!
I did a little searching and found this option: Online Shop Toyota Land Cruiser LC200 FJ200 2008 2009 2010 2011 2012 Aluminium Alloy Roof Rack Side Bar Rails|Aliexpress Mobile
But I need confirmation it will work, also is there a way too just get the one piece I need?
Thanks in advance!
Sent from my SM-G920V
Your Toyota dealer should be able to identify the part number you need. Probably cheap, and could order through them if you don't find it online.
All Land Cruiser parts come out of the pot at the end of the rainbow.
Ha, yeah, I was hoping to order just the one piece I needed instead of the whole assembly kit. Looks like my toyota service tech is going to get (another) call from me.
Thanks all.
I have seen posts about these piece parts just flying off people's Land Cruisers. Are they really necessary? I have not even checked to see if I have mine.
I think I need 75556C (LH)? x 2 of them - lh = left hand = driver side? They sit inside the stamped groove of the metal roof and make it nearly flush *before* the luggage rack and cross bars sit above them. See attached, but I think the part number would be 75556C(LH).
If anyone has extras lying around, I'd be interested to chat. Otherwise, I'm happy to order from my dealership - thanks again!
When in reverse and you get out of the reverse camera (I.e when you hit climate to change the air) is there a way to get back to the camera without going back in park?
Those look like the channel strips. I don't have those.
Sorry
Have you tried hitting the view button to the right of the steering wheel below the speedometer?
That might work.
Try a quick shift to N and back ;)
