speedo
hi
want to change my speedo on my fj40
what is the easier way and what model can i use?
do i have to change the cable??
thanx
You will need to tell us what year truck you have, and even that may not narrow it down, as someone could have changed things over the years...
Do you have a push on connector at the speedometer head, or does it thread on?
thanx POSER
it's a 1984 diesel fj40 (bj42)
with a push on speedo connector
bye
Why do you want to change it? Is it INOP?
Do you want to go to the earlier 80's or late 70's version?
O cool, there is a guy on ebay and there might be someone here that does a drop in aluminium face with pre drilled holes for popular guages.
If you sell yours I would like to buy it if available.
Look around and do your research on parts, there are alot of small business people out there/here on mud that are willing to take the time to help you out and get you what you need.
Best,
Shane
shane
thanx
for the aluminium face i can do it myself
it's the parts i'm looking for
bye
I had a stock cable modified to fit Autometer / standard US hardware. Look around there were a bunch of places near where I live that mess with cables.
x2. Most speedo shops are set up to mix and match cables and ends. They'll just cut the lower end off of your cable housing and inner cable to adapt onto a new cable that will match your new speedo.
It's been a little while since I had to get one of these done for a customer, but IIRC it ran ~60ish, just to give you an idea what they run. Might be good to check with a shop BEFORE you buy the speedo.
Hth
Mark A.
aluminium face
anyone know who makes them or where i can get one? id like to make one myself :)
