Special service tool (1 Viewer)
Does anyone can let me know where can I find the tool below?
09275 54011 Plunger Stroke Measuring Tool
09992 00024 Cylinder Compression Check Gauge Set
09992 00400
Thanks.
So if it is the FST
You need a special dial gauge, this is what I use.
It all about the shaft on the dial gauge and it fitting the FST. It’s a kind of uncommon size in the USA, 7 or 8mm if I recall right.
Cheers
I'm not sure that the mechanic said the factory setting does not work now. The 80 has been run for 30 years. The factory specification may not be applicable now.
If the engine won't run properly with the injection pump timing set to stock range, then the injection pump and injectors are WAY beyond needing to be rebuilt.
So if it is the FST
Cheers
Dude thanks for posting this!!! I need to find a dial indicator that fits and measured my tool and its 8mm
