Thought I'd post my speaker install that I just did with the help of the search function and compile what I found in several threads that may help others.
Here is the link to the door panel removal thread that was very helpful.
https://forum.ih8mud.com/100-series-cruisers/327860-door-panel-removal-process.html
Only two things I might add to the door panel removal writeup is that the panel is easier to take off and put back on with the window rolled down, and the trim piece around the door release is easily removed if you put a small flathead screwdriver between the lock latch and the trim piece and push up and then between the lever and the trim piece. Dont try to pry between the trim piece and the door panel.
I had to gut part of the original woofer to use the rest of it as a mounting bracket. That was the only modification needed.
BTW on the drivers side, Pink wire is + purple is - on passenger side Green is + and blue is -.
