What is the actual tire size you are running? Is it a 285, 295, or 315 width tire? And i didn't see any mention of spacers. I'm running 1/4" spacers with my 315's and I think most others are too.
Was it squeaking?View attachment 1124834
2004 Toyota Landcruiser
SPC BALLJOINT
DATE Installed 4/17/14
MILEAGE Installed 135,468
Current MILEAGE 154,003
Date Replaced Driver Side 8/20/15
Lasted 1 year 4 months before I had Slee Warranty SPC Balljoint, didn't last 20,000 Miles
I had to have mine replaced after about 10k miles, slee replaced both of the and said they had a bad batch. I was just informed a couple weeks ago that the new ball joints are no good! About 4k miles on these ones. Frustrating to say the least!View attachment 1124834
SPC BALLJOINT
BenI had to have mine replaced after about 10k miles, slee replaced both of the and said they had a bad batch. I was just informed a couple weeks ago that the new ball joints are no good! About 4k miles on these ones. Frustrating to say the least!
It doesn't sound like it will be as easy to get the second set warranted out.
How many of you guys have had problems with the spc ball joints?
Your right, it does not make sense!Ben
did they show you that they were bad? 4k on a set does not make sense for them to be worn again. What shocks are you running?
We have not had a single failure on the latest batch of joints. If they are loose and there is nothing in the suspension setup that is causing this I would suggest we get in contact with SPC engineering and have them comment on it.
Can you get a video of how the shop evaluated it?
But sure enough I did the front wheel bearing service and still have some movement in the tire. Its pretty simple to evaluate, jack the front end up, grab the top and bottom of the tire and see if there is movement. The wheel bearings are good as well as the lower ball joints, I can put my hand on the upper and feel the movement.
Also the ball joints are not directional and can not be installed wrong/ backwards,
I will likely be going a different route on the upper control arms, I can deal with one failure but not 2. It's not worth it on a vehicle that I frequently load up the family and drive 1000s of miles at a time.
how do you know if you were sold a bad batch of theseBen
Looks to me like it's installed correctly, the bj should be offset outwards. I bet the offset bj had those guys scratching their heads and assuming it was installed backwards but it's not. Here's a pic taken from the instructions that show the correct orientationWhat does a backwards ball joint look like? I ask because I was told tonight after the shop installed them that mine are backwards. If so I’ll get them fixed ASAP. Here’s a pic...
