Spark plug wires are loose.
Chicago
I purchased some Denso spark plug wires from Matt and they are very loose on my spark plug (NKG) terminals. Anyone else have the same issue? Any recommendations on how to remedy?
Thanks,
Sam
Seems odd. Some spark plugs have screw on knobs on top, maybe you could swap to bigger ones. Inside the boot, there is usually a metal clip with a split. Perhaps you could insert a small screw driver and tweak the clip closed at the split to better grip the knob.
Maybe get some different plugs, take a wire to the store and see if the new plugs fit better.
Have you ask the person you bought them from.
Thanks,
Sam
Pliers are your friend. Don't go crazy, sneak up on how much you squeeze. Test fit and if still loose squeeze a little more. Don't forget a little lube on the boots.
Thanks,
Sam
Are these the same plug wires you posted about in early July? Pliers wasn't the answer then? How about a pic of the sparkplugs you're trying to fit a wire on?
