After searching endlessly for someone with the same AHC issue, I’ve finally decided to throw it out there and see if anyone has a solution.
2006 LX470, ~90k miles, owned since 2021. Wife’s daily driver.
AHC selector has been non responsive since prior to our ownership. No joke, here is the daily procedure:
-Turn ignition to “ON” (but do not start). After approximately 5 seconds, ride height will LOWER roughly .5”.
- Turn ignition to START, i.e., crank the truck: after approximately 5-10 seconds, the AHC system will RAISE the height by about .5”.
It also seems to successfully level out the front and rear.
As you can probably surmise, if one goes about their day running errands, (assuming you start the vehicle 6 times) you may arrive home 3” higher than when you left. When it gets too high, you just turn the key to ON, let it drop .5” at a time. Turn the key ON, let it drop, turn it off, repeat until at desired lower height.
While we’ve somehow managed to make this work, and for the most part we have: nonetheless, it’s definitely taking a toll on the front tires by way of inconsistent alignment.
3 years ago, I flushed the AHC system with no changed results. I also replaced the relay in the engine bay fuse box. Again, no change.
If anyone knows how the ride height could possibly be changing with the turn of the ignition key, please chime in. Again:
Key ON: ~ .5” LOWER
Key START: ~ .5” RAISE
No response from the AHC selector switch. The simple answer would be to replace the switch to see if it resolves the issue, but I’m curious if the switch goes out, how does the height control then move to the ignition switch?
Update: after running Techstream, here’s the data generated along with the current error codes:
Key ON: ~ .5” LOWER
