4Cruisers
I'm contemplating selling my '93 4-Runner in a year or so. It's a white 4WD with 3.0L 3VZ-E, 5-speed manual, and 31X10.5R15s on OEM alloy wheels. Body is in decent shape. Purchased used at Sauter Toyota in Santa Fe in January 2001, with ~144,.000 miles at that time. I'm the second owner. The dealer determined it hadn't had the head gasket recall, so that was included in the price. They discovered the block was warped so they also installed a brand new Toyota short block, also included in the price. I also had them do a valve job and timing belt replacement. It now has ~285,000 miles.
I recently decided it was time for a timing belt replacement and complete tune-up, etc. My son and I are finishing up the work now. We used an Aisin timing belt kit with Mitsubishi belt, Aisin water pump, new tensioner, and idler bearings (OEM supplier parts); adjusted the valves; rebuilt the power steering pump with a new Toyota gasket kit and air control valve; installed new plugs, wires, distributor cap and rotor; performed an oil and filter change; had the radiator flushed and pressure tested, installed a new thermostat and gasket, and replaced the engine coolant. It also has new tires.
With all the recent work, I was thinking it might be a good time to install an All-Pro Off Road solid axle conversion. I really like the solid front axles on my four Land Cruisers. If my son and I do all the work, I was thinking I might get my money back out of the cost of the conversion, especially here in the local market. Any thoughts or input would be appreciated.
