For Sale Socal rebuilt 12HT drivetrain sitting on a 80 rolling chassis with a 43 body.
  1. 40 Series
  2. 80 Series
Array
I have a BJ43 body on a 80 rolling chassis cut and fit with a rebuilt 12HT drivetrain with the H55F for sale asking 17K. A custom rollacage was made for the BJ43 and was tied into the chassis. The 12HT was rebuilt by Chris at Wink 4X4 out of the Netherlands. The tires with the methods are 37’s for mock up and reference.
thanks
Mario
Wow that is a pretty sweet project and already a ton of labor done to it . Remy and Chris at Wink do good work so that 12HT will run good.
glwts
Pm sent with fingers crossed😬 hoping we can make a deal without the motor and transmission package 😢
I'd be interested in the engine/transmission if that is what you are after.
Definitely interested.
Do you have details on the rebuild?
Alfin Pistons?
Crank work?
Block machining?
Toyota gaskets?
Injection pump rebuild?
Head work done?
Intercooler info?
Accessories included and new? (alt, water pump, starter, etc.)
New clutch?
H-55 rebuild with new (Japanese) bearings/seals?
That's a lot to ask, but answer when you have time. I figured I would ask here, rather than a PM so you don't have to answer every person with the same questions.
Cheers.
Alfin Pistons?
Crank work?
Block machining?
Toyota gaskets?
Head work done?
Intercooler info?
New clutch?
Cheers.
They are all going to be questions for Wink most likely so I will let Mario answer when he gets online. I only thing I know is its clean and has certainly been apart and was test run before it was shipped and I believe was built for Wink's car but then he went to a 1 HDT so I would expect it was built with everything expected but I would only be guessing.
Where in Cali ?
Also interested in the 12ht if the deal falls through.
