I also got to work on my storage plan for the back of the 74. Plan is to bolt down a piece of plywood cut to mach the floor of the cargo area with out the rear seats. The wood will be covered in vinyl and have three strips of L track or airline track, to mount the fridge and storage cases down. This will be a semi permanent set up, I am taking out all of the rear seat mounts to get a level floor and use the some of the holes to mount the board.
It will be similar to the back of my 80 but with out the drawers:
Here's the 80 so you have an idea where I'm going with this.
Pulling up the carpet to get to the mounts.
I have a hard time believing that Mr T used a stack of washers for the seat mounts. Do others with split seats have this same set up?
Mounts removed and floor cleaned.
I just used some silicon to fill in the holes I won't be using to mount the board and the L Tracks. I use silicon so that if I or some one else wants to remount the seats and mounts it would be easy to clean out the holes and bolt them up.
I looked at adding some sound deadening but I think I will just leave the carpet in to serve that purpose, and look at the sound mat when I tackle some of the rust spots on down the road.
I got the board all cut out and the vinyl glued and tacked on. Just waiting for the vinyl to dry and then I'll cut it to form.
The staples will all be covered up with aluminum trim on the ends and the L Track on the sides and one down the middle. L Track should be in this week and I'll get it all finished up
