So I think the Michelin Defender is the perfect all-terrain tire... (For most of us) (13 Viewers)
Not a Defender specific question, but for those going from the factory 285/60R18 to the slightly larger 285/65R18, do you notice any weird or quirky shift point behavior? Like the truck is not in the power band, or is hunting for the right gear?
On my 80 series, I went from 285/75R16 to 315/75R16 and it was fine. But when I went to 295/75R16 it seemed to have trouble finding what gear to be in, and it was often not in an optimal power band for the speed I was driving.
I think I want to get something smaller than the 275/70R18 I am using now but feel the stock size isn't going to be big enough. The 285/65R18 may be what I end up with but want to make sure there aren't any driving or shifting issues with that size.
I went up to 285/65R18 XL Michelins. No strange shifting at all. Didn't feel much different at all. Imperceptible.
On sand, high
Sorry to derail the convo, but are the KO3s that bad, given they’re readily available, at least in the Bay Area?
I have ko2s on my 62 and like them.
Want something in the 200 that I’ll feel safe in on some off road trails given it’s at stock height. I had quite a tough time recently on the beach with stock tires.
I like the idea of the Michelins, but seems to be quite a challenge to get the ones people like.
For beach and sand, tires with less aggressive features like a highway tire are actually more effective. Because they tend not to dig as easily.
There's still the dimension of floatation however which is dependent on the tire surface area. This is where airing down is key, to something like 15-20 psi, depending on how heavy your are and also how loose, hot, and dry the sand is.
This is also where dimensionally larger tires make a difference. Because of more sidewall and the larger footprint they can put down. With more capability to air down further to get more floatation still.
In the southwest where there exists crazy silt beds in the Baja like dessert, maximizing footprint can be critical to avoiding stucks at overlanding weight, which is why I prefer full fat tires.
If there's one thing to takeaway, is don't roll into sand at highway tire pressures.
Yea to clarify I didn’t have a compressor, so didn’t air down. But I will say my friend, who also didn’t have a compressor, didn’t let his ko2s down and did a bit better on the sand.
Here are the stock-size (285/50/20) defenders on OEM rims.
Recently had a chance to use these tires off-pavement. About 1.5hrs on a forest service road each way (in/out), towing that same trailer. 20PSI all around, no issues whatsoever. Comfortable, confident ride.
Same vehicle or something lighter? Were his KO2s stock size or larger? Unless his vehicle is identical, there's many variables at play. Including driver and vehicle settings like locking the center diff to also turn off traction control.
For everyone airing down to go on the beach, are y'all running LTs? Or Ps? I was under the impression it was bad to deflate P rated tires.
I ran my non LT michelins at 18PSI for nearly a week straight without airing up in CO at the LCDC event last year in Ouray with no issues.
I don't think I ever had LTs on my Durangos or Jeeps and always aired down.
I just got back from Colorado where I took my stock 2019 LC with Defender LT and they performed superbly on both Cinnamon Pass and Engineer Pass on the Alpine Loop. There were a couple of spots going up Engineer Pass from Silverton that I didn't think I'd get over, but we found the line and it didn't slip once, even though everything was slick from rain. One friend had KO2's on a Nissan Frontier and the other was running Falkens on his 4Runner and there were multiple sections where they were hitting and I wasn't. I still love the look of a more aggressive off-road tire, but these worked so well I'm not sure I'm going to switch.
I'm currently running 33 x 10.5 BFG on my FJ62's 15" wheels with a 2" OME lift.
I'd like to switch to slightly smaller Defender LTX M/S 2, but 16" is the smallest diameter wheel size they offer.
If I buy the City Racer 16" wheels, will I be able to use Defender LTX M/S 2 in 265/70R 16 (roughly equivalent to 31" x 10.5) ***without any other modifications***?
Might want to try posting in the 60 Series Forum here: 60 Series Forum
This is the 200 Series Forum...
HTH
Those City Racer wheels are only 5.5” wide. Michelin recommends 7” to 8” wheels in that tire size. I don’t think you’ll find a shop to mount them on a 5.5. Probably not safe either way?
If the Defender is available in 235/55/16 on 70 series wheels would match what you are wanting for tire size.
I noticed that, didn’t think to check after @32cls6speedmt had posted his conversation with them.
Hi everyone,
This weekend I purchased a 2020 Land Cruiser that has about 55k miles. The tires included on the vehicle are some Open Range (Les Schwab?) AT Tires. I'd like to move back to a more moderate tire for mainly highway driving some dirt travel to get to rock climbing spots.
My LC has the stock 18" wheels, calling for a 285/60R18 tire.
My preference would be to purchase the Michelin Defender LTX M/S2 based on the reviews I've seen on the site. The only problem I have is all of my local dealers seem to not show this as an option on their website for ordering.
I have checked Americas Tire (Discount Tire), Costco, and my local Toyota Dealership.
The dealership is of course recommending Duelers, or they offer a Geolander H/T G056.
Does anyone have more information here? I don't have a trusted installer to work with, and I don't want to risk a tire rack purchase.
I'm leaning towards just having my dealer install the Geolandars. Any advice?
Hi everyone,
America's Tire / Discount Tire is now Tire Rack - same company. The Tire Rack site certainly shows the tire you want and should be no problem ordering through your local America's Tire / Discount Tire store:
HTH
Hi everyone,
As noted you can find Michelin Defender in stock size via Tire Rack. But many here pick the Defenders in alternative sizes with a bit more sidewall, such as 275/65r18 or XL285/65r18, both of which will fit your truck with no modifications.
