but her face is full of our country's finest bugs.....It takes guts to do that.![]()
My single exhaust from the SBC is routed outside the frame and runs all the way back on the driver side to exit in the stock location. Have center dump manifolds into a Walker tube crossover, then custom from there back. No issues for 13 years now other than some melted soundproofing on the floor quickly remedied with a heat shield over the muffler. Duh!Started the clean up and checking over things. I found the exhaust leak, once again the header collector gasket blew out. I believe that's the fourth time and three of times I had my exhaust guy check alignment, etc. before putting new gaskets. I've tried different type gaskets and still they blow. I'm going to pull it all out, cut off the three bolt flanges and weld on V clamps.
Question... I want more front axle travel, right now the u joint flange will touch (without the bump stop) the exhaust pipe that crosses over under the oil pan ( chevy ). So, I'd like to run the pass. side pipe down and outside the frame then cut back in behind the transfer case. One problem is I'd have to go under the frame or through it to connect back up with driver side. Any opinions? Thoughts?
Checked trip miles, a tad over 4,000 and averaging between 13 and 14 MPG. I'm hoping that "lean bank" code was due to the exhaust leak.
Contemplating dual to the back as well on a build i am doing LS (different truck). Keeps it simpler. Breaths a little better. Sounds better@landcruisnman routed in front of the engine.
I see a lot of ppl fussing over the cross over pipe. Is it that hard for everyone to go dual to the back? I had no issue.
What gaskets are you using and do you use locking hardware?I've tried different type gaskets and still they blow.
I've tried three different types, one was a pure copper gasket and the others were cork? and metal combo. The nuts were the problem on the first go round, so tried some threaded rod connectors with a set screw in the end, this wasn't my idea, but they seem to work and stay tight. I never had problems with my old 327 in the 40, so instead of fighting the 3 bolt I'm wanting to cut them off and weld on the V clamp.What gaskets are you using and do you use locking hardware?
My problem with that is the transfer case shifter rods on the pass. side. There's no room to run back inside the frame. I would have to run outside then under the frame or through the frame to connect to driver's side. I'd rather not have dual exhaust all the way back.I see a lot of ppl fussing over the cross over pipe. Is it that hard for everyone to go dual to the back? I had no issue.
I looked at this again and in order to make that work the pipe would be under the frame anyhow. The transfer case rods are right there and my trans. mount/skidplate below them. I could redesign the mount/ skidplate so at least the pipe would be protected, an option.@landcruisnman routed in front of the engine.
