- Thread starter
- #21
Well, you don't have to pull the connector off... all you really have to do is interrupt the the black/blue wire from the ECU to the L4 switch. Connect it to a switch, connect +12V on to the other side of the switch. When the circuit has power, the transmission will shift using the low range map, when open (no voltage) it will shift using the high range map ("easy shifting"), giving you full control. This includes overdrive.
That's great! Thanks for the details.
Sent from my iPhone using IH8MUD
