Dude, look at your own pic of the deflated tire, what is the tread of the tire doing?
Not becoming shorter
C-yah later, but not in this tread again. My aspirine bottle is empty
Dear Mark, that is exactly the point at which I think that you forget something. Math wise you're right. If you decrease the circle, the arc gets smaller. But because the amount of tread in the real world stays the same (I don't swallow the idea of shrinking rubber - not that much), it's a total different story.
You are confusing degrees of rotation with linear distance (measured a the circumference).
5 degrees at 1 foot from the center point is much less than 5 degrees at 10 feet from the center.
Your diagram clearly shows the difference if you shift your mindset a bit.
Rubber DOES stretch and deform... and so far as the point at the tread is concerned it DOES speed up and slow down.
Mark...
C-yah later, but not in this tread again. My aspirine bottle is empty![]()
