Show off your 100 beast with 35's..... (6 Viewers)
One more pic - from her good side...
Proportions look great!
Are these the zero or +25 offset method NVs ?
0 offset confirmed! Did some more pinch weld grinding, pushed the upper fender tabs in annd up angainst the fender, and heat molded the upper fender lining to be a little more flush with the fender. Also extended the front bump stops maybe half an inch. Still gotta do some flex testing but no more rub when turning or hitting speed bumps exiting the parking garage.
0 offset confirmed! Did some more pinch weld grinding, pushed the upper fender tabs in annd up angainst the fender, and heat molded the upper fender lining to be a little more flush with the fender. Also extended the front bump stops maybe half an inch. Still gotta do some flex testing but no more rub when turning or hitting speed bumps exiting the parking garage.View attachment 3594457
Thanks for getting back to me
Would love to see some pics from different angles once you get in dialed in - May take some driving, adjusting, driving, adjusting but it looks like you’re heading in the right direction
Deleted
How has been steering rack reliability for people who have been on 35s for longer time?
I always heard that the rack is not particularly happy with the larger tires. I am up both for new tires and new rack and 35s do indeed look mint and would be helpful for the trails we have around, where there are lots of Patrols on 35" and lots of lumber trucks so often the ruts are a challenge on 33s.
Well it's not crazy long term but I've got 2 years on the 35s now and so far so good. I'm sure the rack will give out at some point now though with 435k on it 😅
Our steering racks don't typically die, their seals start leaking because there isn't enough cooling for the fluid. Flushing it regularly should improve its life
Updating on clearing the 35s 0 offset.
I just wheeled and flexed as much as it will go so I am finally happy to share.
I am sitting at 21.5 in the front and 23.75 in the rear currently
1. Pinch weld as far back as I could cut
2. Extended OEM front bump stops by .75 inches. Some washers and some welding.
3. Rear of the Front fender (slider side) folded in .75-1 inch.
4. Rear OEM bump stops extended .75 inches with spacer
5. Cut 1 inch off rear BIO bumper where it was rubbing on stuffage.
6. Clearing windshield washer fluid container w/o any trimming
Nice, thanks for sharing. Do you know your caster? Imagine if you push the wheels forward you can further clear your rear fenders on the front. Might start touching the washer fluid reservoir but that’s pretty manageable.
I am not sure the caster but it's in range for factory alignment due to the correction in the dobinson control arms. I've already folded in the fender so all is good now but could be a good option for others
Crazy how much articulation we get in the back isn't it???
Yes it's epic! Running icon 2.0s and extended sway bar links now which is helping. They are a little bit longer than OME I was running before.
Counts! Sick rig and great talking w you and meeting you at CRR.
Kind of counts….I guess. 35’s. 80 frame. 100 body.
