- Thread starter
- #21
I found lots of them - that would require shipping. Shipping is in the neighborhood of $200. I'd rather be patient and pick them up locally... or semi-locally.
As for your assertion that "6000lbs of truck is plenty of kinetic energy to plow through stuff without additional flywheel effect from the wheels":
Thats like saying that a 230 hp truck has plenty of horsepower already,
which is true for most situations.
But high performance comes in small increments, and is predicated on the metric used for measuring "performance."
In some situations, the heavy wheels make the truck ride smoother and handle better. In particular, heavy wheels really excel on rough roads at constant speeds. The theoretical physics back this up.
If you spend most of your time accelerating and decelerating, which is what most people do, then the light wheels are preferable.
If you drive washed out gravel roads with the cruise control on 70mph, then the heavy wheels are your friend.
That said, your point about the inverse relationship between unsprung weight and suspension performance is absolutely correct.
If you drive washed out gravel roads with the cruise control on 70 then you will need to replace wheel bearings and suspension bushings pretty frequently. The LC is still a pretty awesome vehicle for fast gravel roads, and the heavier steel wheels only make it better for this application.
Sam at Lowe Toyota can get them for ~114 a corner.
Two things:
1. Maybe it's S.E. Toyota - but there are NO Tundras anywhere near Atlanta with the "standard" 18" steel wheels. But I'm patient
2. UPS and FedEx trucks have steel wheels. Huh? What does that have to do with anything? These guys plan their routes to avoid left turns. The entire business model relies on maximizing efficiency. We know aluminum wheels are plenty strong enough for their trucks (18-wheelers use'em). And we know - from all the above physics lessons - that aluminum saves a lot of rotational weight. So why the steel? I'm guessing because they are cheaper to replace (when they curb'em) and the fuel savings is negligible? Maybe?
Dumb question....
Why are these steel wheels so desirable? Are they more durable?
Yes and I would rather jack up a set of $100 wheels on the rocks vs a set of forged alum OE wheels. Plus I like the look.
I got a set to run when I go play in rocks so not to mess up the OE powder coated wheels that are on my truck when I got it.
Thanks, thought there was a bigger difference.
The less mall cruiser, more poverty package Mid East styling may be desirable to many.
