jim land
you can convert it to leaf spring
maybe you need more caster
I like this idea. Waiting to see the pics of finished product and hear how it works. My parts washer sets on a 20 gallon barrel and can't be sealed, so the solvent does evaporate over time.
Don
Would it have been cheaper to simply buy a $1,500 crate V8 engine?
You know, I never did complete this thought. So it is together and I use it fairly regularly. Originally, I went with just air pressure to draw fluid out of the 5 gallon bucket of cleaner. It works, sort of, there are a couple issues. 1) if you want to soak anything, getting enough cleaner into the wash tray takes a coon's age, and 2) while it does an amazing job of blasting stuff off (air pressure with some cleaner) it creates a fog that is tough to see through. The next update, and it's current state is I have a 12v fuel pump pushing fluid through the nozzle and I can add air pressure to it. Still has the same problem about fog, but it works a lot better. Next up is going to be attaching a brush to the nozzle so that fluid comes through the brush. I don't use it a lot, but it really does work quite well. I also cut the gloves out... not sure that was a good idea, but I'm not putting them back. Most times when I use it, I've got latex gloves on - and those do not fit with my hands in them inside the gloves that come with the machine....
upgrades will eventually be a larger-volume fuel pump, a switch on the pump, and a brush on the nozzle...
Got a new tool, this thing is cool
and it cuts quite easily
making chips
this was the coolest part.... square, no heat.... large chunk, didn't take 30 seconds to go through it
and it came with 2 blades for less then $200 - do wear safety glasses, it tends to through chips all over the place
