What size are stock shackle lengths??? Also, thoughts/opinions on the following...
In an effort to resolve wandering steering issues, I'm getting ready to replace my spring/shackle bushings (already working on the center arm housing replacement too to solve what I think is most of the steering issue...so no need to point that out).
Since I'm going to be replacing the worn shackle bushings, I might as well consider shackle upgrades while I'm already removing/re-installing these parts.
Oh, my suspension is **I think** a BDS lift...not sure if 2.5" or 4", but the shocks are defintely BDS (was installed by PO). No caster correction shims are currently installed. I'm running 33/12.5's MTRs on 15" wagon spoke wheels...this set-up does not rub in the front or rear except in situations of extreme axle articulation.
Here's what I have in terms of shackles:
FRONTS
- appear to be basic flat stock steel shackles
- 3" center-to-center bolt distance (total shackle length of 3.5")
REAR
- definitely not stock
- 5" center-to-center bolt distance (total shackle length of 5.75")
Just trying to figure out what I have... The rear sags just a little compared to the front after I installed the **heavy** MAF rear tire carrier...and will likely sag more once the hardtop is installed. So another reason to consider shackle options at this point.
FRONTS
REAR
