Josie'sLandCruiser
Stop calling it a "FJ."
Hi All:
As some of you may, or may not know, I blew the front pinion shaft in my FJ40 last weekend while 'wheeling.
I've got the donor axle assembly taken apart, now I'm trying to remove the third member from the axle housing.
Normally, when the axle is bolted to the truck it is no problem, simply jack-up the pinion end and the third member section will pop loose from the axle housing.
But, in this case, the axle is sitting on jackstands, so I can't do the above trick. Any suggestions for breaking-loose the chunk from the axle housing?
Thanks!
Alan
Thanks!
Alan
