sensitive gas pedal
anybody have a fairly sensitive gas pedal? like you start to press it and it doesn't necessarily feel like it hangs up but it doesn't actuate real well. makes the truck feel kinda jumpy (not major just a little)?? Is this pretty normal? not a huge issue, just feels like it should be more smooth.
Brian
CJF
Brian
My '91 idles at about 650, but pressing the pedal even reeeally lightly jumps the rpm's to 1,000 or so. Probably a throttle position sensor issue, but I haven't tried to chase it down. Definitely wouldn't hurt to run the FSM tests on the TPS.
Curtis
North Cadillac
Actually i think that a really sensitive throttle is a combination of a clean throttle body and a new or great condition throttle cable.
If the throttle doesn't seem to actuate very well, i would look at those two culprits first.
Hoosier Daddy
CO Springs
I had this problem - I replaced my accelerator cable and it cured it.
This is a relatively easy and cheap thing to do, so if your accelerator cable shows any outward signs of being original (cracked plastic or such), I'd replace it.
CJF
Pedal to cruise control or cruise control to throttle body or both?
Mine used to snag a little with the old throttle cable.
I replaced it and its much smoother accel now
