I Need to tighten the crankshaft pully bolt but the engine keeps turning over. Anyone have any secrets? It's on the pickup so it's a 20r engine. Thanks.
Take out a plug and feed some decent sized rope into a cylinder coming up on tdc.
Which way does the pully turn? Can you put a breaker bar on it, next to something solid and spin the motor over? Done that dozens of times.
ing ability. Is this the bolt in question?Kenny, I believe it is a 36 mm. I used a 1 7/8 wrench to tighten it on Scotts 62. You can hold the flywheel with a prybar at the bottom of the bellhousing.
You can't get a socket in there with the radiator in the way, but NAPA sells one.(3/4 drive)
Wait a sec, have you been riding around w/ the crank pulley bolt missing? that might not end well Kenny.R
