If I were going down the road of 100 ifs transform, I wouldnt consider a sas, and would just go new evo coil over bypasses on the front, with a cross over a arm design off a new subframe in the front to hang it all from and new spindles to take some pressure off the rack ends, and I would aim for 3" of lift, and super long travel using 14" rear shocks and 10" stroke fronts.
I would speak to Mr Podvin about his flip front set up, and make the fenders larger to fit the 37's on live axle rim offset, with built in flare, to keep the wheel to arch ratio in proportion, and I would move the rear diff back 20mm and trim the rear side so the 37's went up into the rear fenders with flares on there to suit, also keeping the fender arch to wheel ratio on gap, and cover cut with flares. I would just run a 20mm tailshaft spacer and make longer arms for this.
This would give a vehicle with great road manners, good clearance under the vehicle running 37's, wider track to match the height, and the suspension having a little more than 1/3 up travel and a hell of alot of droop, especially the rear.
I would set the front with 1.5- 2 deg neg camber, run 20" rims with the 37's, and rn slotted rotors and upgraded pads, and have a nice handling vehicle at speed with the set up, for the fun parts, and a vehicle with heaps of droop for crawling over obsticles when required.
V8 AVO turbo, and 5 speed auto for the drivetrain with a nice KAAZ or detroit softlocker rear, and air locker front .
