SOLD San Diego - 1994 - 3X Locked - 1FZJ80
Year
1994
  1. 80 Series
Mileage
270000
Color
Gray
$10,000 obo
1994 1FZJ80, 270,000 miles
Second owner. I purchased in 1996 from original owner with ~30k-miles in San Diego. Clean title. Runs great, no oil leaks, AC blows cold, cruise control works great, ABS/LSPV delete. I live at the beach and there is light surface rust on the undercarriage due to damp mornings. The truck has been in San Diego since new.
BUILD:
Triple-Locked *** 14” Front Rotors w/ Wilwood Calipers *** Wilwood Rear Calipers *** 4.56-Gears *** Marlin Crawler TC Gears 3.12:1*** DC Front Driveshaft *** Metaltech Front Bumper *** 4X4 Labs Rear Bumper *** Fox 2.0 Shocks *** Delta 4 Front Arms *** Dobinson 4” Front Coils *** ARB J-Spring Rear Coils *** Dobinson Adj. Upper & Lower Rear Arms *** Dobinson Adj. Front & Rear Panhard *** 555 Rod Ends *** Dobinson Steering Tie Rods *** DIY Sliders *** Goodyear Duratrac 285/75-18 (35 inch) (installed @ 242k miles – 06/2020) *** TRD Branded BBS 18-inch Wheels.
RECENT NOTABLE MAINTENANCE:
Full Knuckle-Birf Rebuild, Lube & Bearings *** Engine Oil, Diff/TC Lube, Transmission Fluid Flush *** Lube Driveshafts *** Alignment/Balance *** Oil Pump O-ring Replacement *** Alternator Brushes *** Steering Box Rebuild (Redhead) *** Steering Pump High Pressure Hose *** Rear Wheel Bearing Rebuild/Lube *** Coolant Flush *** Brake Fluid Flush *** New Plugs *** Transmission Rebuilt (225k miles) *** New Water Pump *** Starter Motor (200k miles) *** Front Main Seal *** Belt Replacement (all) *** Idler Pulleys (all) *** Throttle Cable Replacement *** Parking Brake Cable Replacement *** Brake Booster *** Swaybar Rebuild Kit *** Windshield Replacement (01/2023) *** Newish Radiator (210k miles) *** New Gel Battery (01/2023) *** Fuel Filter (240k miles)
OTHER:
Front Seat Leather and seat foam replaced *** Sound damping throughout interior *** Sony radio/stereo with backup camera & Android Auto/CarPlay *** Birfs drilled for Zerk Fittings. All Toyota original glass except for windshield which is new (aftermarket).
ISSUES:
Dings and scrapes in left and right rear quarter panels. Driver’s side door handle is white (I’m looking for a gray one). Seats and window motors work great until it gets below freezing and then they are slow. There is a little water intrusion in the driver’s side rocker panel. I haven’t been able to identify the source yet.
Dude put more effort into a $10k listing than most put in when selling 70K plus trucks. Nice looking 80.
Agreed, Parts list alone is close to the asking price.
Great deal for someone that what's to go wheeling !
If I bring another cruiser home I will be sleeping in it 😂
