SOLD San Diego - 1994 - 3X Locked - 1FZJ80
Year
1994
  1. 80 Series
Mileage
270000
Color
Gray
$10,000 obo
1994 1FZJ80, 270,000 miles
Second owner. I purchased in 1996 from original owner with ~30k-miles in San Diego. Clean title. Runs great, no oil leaks, AC blows cold, cruise control works great, ABS/LSPV delete. I live at the beach and there is light surface rust on the undercarriage due to damp mornings. The truck has been in San Diego since new.
BUILD:
Triple-Locked *** 14” Front Rotors w/ Wilwood Calipers *** Wilwood Rear Calipers *** 4.56-Gears *** Marlin Crawler TC Gears 3.12:1*** DC Front Driveshaft *** Metaltech Front Bumper *** 4X4 Labs Rear Bumper *** Fox 2.0 Shocks *** Delta 4 Front Arms *** Dobinson 4” Front Coils *** ARB J-Spring Rear Coils *** Dobinson Adj. Upper & Lower Rear Arms *** Dobinson Adj. Front & Rear Panhard *** 555 Rod Ends *** Dobinson Steering Tie Rods *** DIY Sliders *** Goodyear Duratrac 285/75-18 (35 inch) (installed @ 242k miles – 06/2020) *** TRD Branded BBS 18-inch Wheels.
RECENT NOTABLE MAINTENANCE:
Full Knuckle-Birf Rebuild, Lube & Bearings *** Engine Oil, Diff/TC Lube, Transmission Fluid Flush *** Lube Driveshafts *** Alignment/Balance *** Oil Pump O-ring Replacement *** Alternator Brushes *** Steering Box Rebuild (Redhead) *** Steering Pump High Pressure Hose *** Rear Wheel Bearing Rebuild/Lube *** Coolant Flush *** Brake Fluid Flush *** New Plugs *** Transmission Rebuilt (225k miles) *** New Water Pump *** Starter Motor (200k miles) *** Front Main Seal *** Belt Replacement (all) *** Idler Pulleys (all) *** Throttle Cable Replacement *** Parking Brake Cable Replacement *** Brake Booster *** Swaybar Rebuild Kit *** Windshield Replacement (01/2023) *** Newish Radiator (210k miles) *** New Gel Battery (01/2023) *** Fuel Filter (240k miles)
OTHER:
Front Seat Leather and seat foam replaced *** Sound damping throughout interior *** Sony radio/stereo with backup camera & Android Auto/CarPlay *** Birfs drilled for Zerk Fittings. All Toyota original glass except for windshield which is new (aftermarket).
ISSUES:
Dings and scrapes in left and right rear quarter panels. Driver’s side door handle is white (I’m looking for a gray one). Seats and window motors work great until it gets below freezing and then they are slow. There is a little water intrusion in the driver’s side rocker panel. I haven’t been able to identify the source yet.
