I have had a couple people ask if I had a build thread over the past couple of years, so I thought I would finally get around to it during some time off. My 2000 LC100 used to be my mother-in-law's daily mall crawler. She bought it new in 99 and used it until 2010 after putting 96k miles on it. Rather than selling it, my in-laws parked it in the garage in their vacation house in Truckee, CA, where they or I would use it occasionally when up there. About a year ago, I talked them into signing it over to me with 98k on the odometer, which is when I took it back down to the Folsom, CA area and started my build.
Since I am a couple of years along, I decided to post the progress so far, and will continue to post some pics and tips on some of the things I have done. For some of the major baselining and repairs, I use a local shop in Folsom, who specializes in Toyotas, and only use OEM or Aisin parts. For suspension and bumper work, I use Stellar Built in Sacramento. They do amazing work and build some very cool rigs.
I love off roading around the Tahoe area, but am just a beginner. This past summer I have taken some increasingly adventurous trips, but they were still pretty tame. I mainly am having a lot of fun tinkering on a car again, and many of the items I have done to the rig are likely unnecessary, but the time spent on them is cathartic and enjoyable to me.
I wrote all of this up in Notepad, and will be posting replies to this thread today. To indicate when I performed the work, I'll put the month and year in each post.
January 2023
January 2023
- Baseline and preventative maintenance
- Changed Engine oil
- Changed Front/Rear Diff oil
- Changed Transfer Case oil
- Changed Transmission oil
- Changed Engine air filter
- Changed Spark Plugs
- Cleaned throttle body, MAF, and intake
- Installed new brake pads, rotors, and fluid
- Replaced Timing belt
- Replaced Tensioner and pully
- Replaced serpentine belt and idler pully
- Replaced water pump and thermostat
- Replaced front wheel bearings
- Replaced fan clutch and fan bracket
- Replaced camshaft and crankshaft seals
- Replaced front CV axles (both were leaking)
- Replaced radiator, hoses, and fluid (original radiator had a hairline crack on the top)
- Installed Slee SS brake lines I had purchased
- Removed wood trim
- Greased drive shafts
- Replaced all factory bulbs with LED bulbs
- WeatherTech floor mats
- WeatherTech cargo mat
- TouchUpDirect touch up paint
- Detailed engine bay
- Removed running boards
- Installed Slee rock slider steps
- Installed LCP mud flap covers
- Replaced drivers door lock actuator
- Installed BlueSea dual USB charging port
- Installed Alpine head unit, amp, new speakers, and backup camera
- New Method wheels and BFG KO2s
- Dobosins 3" IMS kit - shocks, springs, torsion bars, diff drop, front UCAs
- Lutz Auto speedometer calibration device
- Plaidwagon seat back pockets
- Slee battery tray
- Slee billet battery terminals
- Odyssey Group 31 battery
- Slee 2nd battery tray with ARB mount
- ARB dual compressor
- Big 3 ground wire replacements
- Switch Pros 9100
- BlueSea SafetyHub 150
- 150A circuit breaker for SafetyHub
- Heater Ts
- Ben's 3D Builds Switch Pro 9100 sunglass mount
- Replaced fuel filter
- Cleaned air cabin air filter compartment, and added filters
- Phone mount
- Spiker Engineering grab-handle Scanguage mount
- ScanGuage 3
- Cruiser Garage A/C drain extension kit
- Cruiser Garage under-seat fire extinguisher mount
- Prinsu rack
- Oil change
- Plaidwagon windshield reservoir tank
- CruiserPatch CDL button guard
- CaliRaised dual light bar
- Additional preventitive repairs
- Brake booster
- Steering rack (was leaking)
- Radiator OEM cracked, but replacement under warranty from 01/23
- Dobensons rear lower control arms
- Tundra charcoal canister and air hoses
- Hurricane Fab tailgate storage
- Dissent front & rear bumpers
- Perry Parts front and read bump stops
- PCV valve kit
- Starter
- Coils
- Seals
