- Thread starter
- #61
Thank you for your input.@2001LC - Thank you for the thought and effort that has gone into the project.
Just to add my 2 cents:
On my 06 lc100, (Mid-Atlantic region- mostly highway use - low dust areas). the p0300 code first showed up at around 185,000 miles. I checked all the usual suspects - complete tune up , checked vacuum& exhaust leaks, AF & O2 sensors, etc and was unable to identify any issues that lead to the Cat failure (assuming that the cat was actually bad). I did remove the cat but did not observe any blockage as shown in your photos. I also tried the Italian tune-up without success. Also for reference the air injection system was operating normally (it went out a couple of years later)
My conclusion at the time was that the cat was Not “bad”, But rather was still operating at 80-90% efficiency - which combined with the very tight parameters Toyota had programmed for 06-07 was just low enough to set off the code.
My fix was to add the o2 sensor extenders ($10) to the rear o2 sensors as I was not willing to pay for new converters.
6 years have passed since then, and the codes did not come back- The vehicle now resides in a state that checks tailpipe emissions, and it continues to pass these emission tests with flying colors. ( with the original cats still in place…)
I would agree that adding a replaceable filter is a worthwhile investment to protect the air pump, valves, and possibly the cat.
I am making no judgement as to your conclusion on the cause of cat failure - Just adding a east coast perspective to your knowledge base.
My limited conclusion would be that All of the 06-07 rigs are ultimately going to experience P0200/P0300 codes in their life regardless of the conditions they are operated in. The cause- overly restrictive programming on Toyota’s part, Which sets the codes when anything less that 90%-95% cat efficiency is observed.
( 2 years later the air injection failed -hewitt kit solved that issue…)
You took the coarse, many have. (02 extenders & S.A.I block off )
Here's the two most important contribution to this thread, I will ask of you:
What is the compression of each cylinder now, and back when saw the first DTCs (if you have those readings also)?
What is condition of the S.A.I pumps filter at this time?
I assume you did not list all DTC. As neither P0300, P0200 is a CAT DTC (P0430 or P0420) or S.A.I DTC(s).
Can you list all DTC in your vehicle history, and the mileage or date when each came up? (If any came up repeatedly, list each occasion by mileage or date).
You wrote: "I checked all the usual suspects - complete tune up , checked vacuum& exhaust leaks, AF & O2 sensors, etc and was unable to identify any issues that lead to the Cat failure"
Did you find the cause of cylinder misfire and/or fuel injector issues, the DTC P0300 & P0200 pointed to?
What were the condition of coil?
What was condition where they, and how difficult or easy was it to remove spark plugs?
Did you find any vacuum leaks?
It has been suggested in mud. CAT sampling parameters in the 4.7L VVT of the 100 series, where set to tight by Toyota.
Perhaps! But to that I must note: I see many 06-07 VVT 100 series. Most have never have set off P0430 & P0420 CAT DTCs.
