I think that I am becoming the queen of real time help drama this past week.
I am searching right now, but it is difficult on a hand held device and so I am asking for a little hand holding.
I noticed rolling into Durango after a 12 hour day that the in dash volt meter is a little lower than usual. Just a needle above the half-way hash mark. Much lower than usual. Well after doing the train and what not I go back to looking at it.
The battery tests out at 12.4V. I pull the terminals and they are clean. The negative terminal needs to be replaced (crack), but is tight.
I tested the voltage across the battery after starting the Cruiser. The volts are 12.04V. I test from the b terminal of the alternator to the negative battery post or either the turn signal light ground or the main ground that comes off the battery and that voltage is 11.8V. No bueno. Correct me if I am wrong, but testing from the B terminal means that the fusible links are not wonky. Testing from multiple grounds would show that it is not likely a grounding issue though I will go and clean those up in a bit.
The belts are tight, about 1cm of deflection at the center. Here are some potential hints at problems. I recently had the engine bay cleaned with hot water to make changing out the leaking valve cover gasket less nasty. I started to notice the in dash voltage meter slightly defecting when the turn signals are on. Searching showed others with a similar phenomenon, but no other issues or fixes.
I guess I could go to Autozone and see if I can get the alternator checked in the vehicle.
Any suggestions or threads to look at would be greatly appreciated.
Thanks.
Thanks.
