RTH: Broken Alt. Tension Bolt
Does anybody know the part # for a 3FE alternator adjusting bolt? I’ve ordered the FZJ twice over and have been trying to find one long enough at a hardware store
The 3FE came with 2 different alternators. The 80 amp version has the external fan and the 90 amp version has the internal fan. Both use different mounting hardware, so you need to be specific.
Or, go to www.partsouq.com and plug in your VIN. All part numbers are available to you.
These parts a NLA new, so take a look at the classifieds section.
NLA. All I needed to know.
The one I had in there was already from the PO that got bent badly. I found an M8 x 1.25pitch by 70mm at the hardware store… I doubt it’s long enough but I’ll keep looking.
Also: is the reason for the tapered bolt so that the whole thing isn’t threaded // ends up bending as you tighten it??
