I wonder if anyone has mounted these to flexible magnet sheet, or Neodymium on the corners.. If you did you could use it when on trips, and take it off when not needed (especially if you utilized a dual source charge controller).
I don't see why you couldn't connect it through the fuse block, pop a 10A fuse in since its a direct connect. If the battery is tied to another you'll want to isolate it.So about 7 weeks later, I finally got around to installing my panel.
Couple things of note:
I can definitely hear some wind noise on the highway and lower speeds.
It sits above the rails I installed - which is not a surprise - so I may try flipping the brackets and seeing if I can get the panel below the top of the rails in the event I need to carry a cargo box or other roof cargo.
My plan of running the wires down the a-pillar was not well thought out. I don't really have a way to secure the wires to the pillar. So I had a lose wire driving to work this morning. This will need to be resolved. I might have enough to run rearward and under the truck to the batter that way. Is there any chance to connect the MPPT to my fuse block in the rear (which is 2AWG +/- direct to battery) or is that just stupid?
Don't pay attention to the fasteners. I was going to try some carriage bolts with wing nuts so I could easily remove the panel if needed. If I have to carry a cargo box, I could just keep the panel in there then remove it and move around as necessary.
I think if that's possible I'd just wire directly to where the leads from the battery attaches to the fuse block. There is an in-line 10A fuse already from the controller. Just wondering if this would be a problem when I'm running the fridge and topping the battery off while parked. I assume there'd be a little voltage drop but may be worth trying out at least.I don't see why you couldn't connect it through the fuse block, pop a 10A fuse in since its a direct connect. If the battery is tied to another you'll want to isolate it.
Check out @tbisaacs great thread, good info for going this route.Curious how you mounted the 80/20 on the factory rails? I have some 80/20 in the shop that would loved to be used up!
Hard to tell, but it looks like you used the 90 degree brackets at each end. How's the support?
forum.ih8mud.com
Have to give credit to @tbisaacs. Look here: Get more from your factory roof rack with t-slotted aluminum (8020)Curious how you mounted the 80/20 on the factory rails? I have some 80/20 in the shop that would loved to be used up!
Here’s how I did mine.Curious how you mounted the 80/20 on the factory rails? I have some 80/20 in the shop that would loved to be used up!
Which profile did you use; 10 (1") or 15 (1.5")?
This turned out awesome
Thanks for the detailed reply. I’m actually toying with mounting the bars above the factory side rails, extending out on each side a few more inches (maybe 54” or 55” total length). This won’t be as aero, but it seems like it might provide a little more flexibility.Lastly, have a friend help you position the bars. I tried a couple ways to do it. If you had more space (your bars were shorter than my perfect fit) then you pre-assemble and loosely attach the brackets to the bar and you and slide the whole assembly on each side simultaneously. As mine was such a tight fit that was a pain in the @$$. I just slid the brackets in individually and then attached the bar after I had roughly positioned the brackets.
It probably will fit both. Is there a good wire loom that would work there? UV resistant?Is it wire thickness that makes the A pillar option not work? The A pillar will fit a 3/8” wire loom. You can secure it with a bit of RTV. Now if you’re using 8 gauge wire you might need to route positive down one A pillar and negative down the other...
I would recommend vinyl tubing which is available in 1/4" and 3/8" to run the wires down the outside of the trim piece, but there may be better choices too.It probably will fit both. Is there a good wire loom that would work there? UV resistant?
I'm not sure what gauge the wires are.
