This image is from a 1976 2F engine. Two of the rocker arms are at an angle compared to the rest. Is this normal, or is something damaged? I can't find any definitive answers anywhere (and I don't even really know where to look).
No tropical delusions here. Definitely not straight on those two.Optical illusion. Ask me how I know.
I think that clears it up. Thanks for your help!Let me see if I can clear this up for you. The portion of the pushrod you think might be bent is actually the end of the valve adjuster that is part of the rocker arm.
The collar at the top of the pushrod is a cup. The end of the valve adjustment stud is rounded to fit the cup. When adjusting the valves you loosen the nut on top and using a screw driver lengthen or shorten how far down the adjuster is positioned.
Hope this helps.
I told you - - tropical delusion!No tropical delusions here. Definitely not straight on those two
