kelly saad
Supporting Vendor
I installed my Rock Warrior wheels and new BFG AT's tires on my 1998 LC today. I used the 1.25 inch Spidertrax spacers as recommended by Slee. I had Toyota install everything because its far easier than myself doing it in the driveway. The wheels and tires are off my Tundra which I drove everyday and so I know the wheels and tires drive perfectly.
On the first test drive I immediately noticed something was completely different with the steering. When I take a 90 degree turn from a stop and accelerate, the wheel doesn't return to the forward, centered position for about an 1/8 of a mile and its pulling obviously. Then once its returned its wandering and driving odd, as if all my tie rods are old and trashed. It felt like something was loose, but nothing was loose, and nothing is wrong with the steering components or suspension. In fact, the entire front steering and suspension is new, and with all Toyota parts: bushings, steering rack, ball joints, upper and lower controller arms, tie rods, OME lift, shocks, sway bar links and bushings. Additionally, the alignment is perfect, also done at at Toyota. I have taken it back in to Toyota and they tested it, drove it and then removed the spacers and switched the wheels & tires back the the old ones that were on the car previous to the change. It drives perfectly again, as it did before the switch (also BFG AT's). The manager said they have seen this issue before after installation of larger wheels with a different offset on lifted trucks.
So, after my experience with these wheels, I recommend not using them. Although I know many out there have them with no issues, I am a different case. If this matters to anyone, I felt it is my responsibility to pass on the experience to all of you out there.
Super bummed out though, it looked so sweet.
