just a few notes on when I changed out the globes on my 06 cruiser:
My suspension on the front was like it had no springs at all - made driving on two lane roads tough although interstate driving wasn't too bad.
I bled all four four corners twice with 2 cans of ahc fluid but got nothing but foam - I assumed this was from a ruptured diaphragm in one or more of the globes which released the nitrogen charge into the fluid. (and continued to release more nitrogen as I bled the old fluid out)
even after bleeding I only had a 5 graduation change on the reservoir from low to high
I replaced all four globes while following several of the threads here on Mud for change-out and bleeding. Rides like new now! Thanks to all on Mud who take the time to post and provide their technical knowledge !
here is a photo of one of the old globes I sliced open - Note the rubber diaphragm which separates the nitrogen charge from the ahc fluid. What may not be evident from the photo is that the rubber layers have de-laminated and apparently had failed. Also note the thickness of the globe walls - as stated by several above, these things hold a LOT of pressure....
WOWSERS!!!!! I had no idea the walls were that thick. I was thinking maybe 2x beer can thickness. Hadn't considered how much pressure these things have to hold.
