the system is designed such that it wont go into low above 3 mph and high above 19 mph is my understanding. the lights will blink but it will revert to neutral.
If you do go into low or high while at a stop, it will revert back to neutral once you exceed the above mph's. Someone feel free to chime in if my figures are incorrect.
Brake depressed for 5+ seconds inhibits AHC.I should have clarified to say even at a stop light in gear but not moving, if I try to raise the truck into High, the high light will blink but it won’t engage.
Took the leap and just ordered Pleiades Spheres from Phil. Shipping is about 3-4 days.
I've already replaced rear springs with new OEM and 30mm spacers. Ride improved but showing about 7 graduations change in the reservoir.
I'll follow up once installed.
That'll be on my list with the Techstream analysis (on order). I don't know the specs at this point.Any other thoughts? what are your neutral pressures? These are fundamental to the system working properly.
OMG. Search. FFS.That'll be on my list with the Techstream analysis (on order). I don't know the specs at this point.
OMG. Search. FFS.
I'm in Canton, right on the Milton border with working techstream/cable. Message me if you want to meet up.Mhmm..
I'd pointed out that reading the system was on the to-do list. I guess the idea was to see if there was anything I was missing while I go through the whole system comprehensively beyond what I've learned of already.
My post was probably premature as I was fresh off the truck and sharing my initial thoughts as others have. I've been searching all night since. (Down the rabbit hole...)
Shouldn’t be any need to try and move either the damper assembly (what you’ve called a sphere mount) or the height accumulator (KYB pressure thingy).Got the front passenger side on with no issues. However the front driver side B&B sphere interferes with the pressure item.
Can either the sphere mount or the KYB pressure thing be moved, which one would be better?
