Replacement rear body mount? (2 Viewers)
Austin, TX
Has anyone found an aftermarket alternative for the rear body mount since OEM (52242-60020 / 52242-60030) has been discontinued? Didnt find anything with ye olde search, but hoping I missed something.
I've not bought or replaced body mounts but I do remember Febest is a brand that makes replacements including the rear.
Read that here on Mud more than once in threads.
edit
Found a box from Onur with all but the 2 rear body cushions. So guess I've bought them
I think you're right, but sadly the Febest TSB-086 and TSB-087 show out-of-stock/discontinued everywhere I can find them.
Well after digging a little deeper, shop.febest.eu claimed to have them in stock and took my money. I guess we'll see if parts show up 🤷‍♂️
Defintely post up the details when (if) it shows up, compare side by side maybe.
Did your old mounts go bad or are you doing this as routine maintenance?
If they did go bad, would be interesting to post that up also.
I don't see any totally split (yet), but they are bulged and dry rotted so I figured I would try to get ahead of this one.
Ordered a bunch of body mounts from Toyota Parts Deal, they just cancelled the majority of them as backordered with no ETA. So I ordered them from Febest US, and they just cancelled my order as Out of Stock. Wondering if perhaps the rest of these mounts are heading towards EOL. Still no word yet on the order from Febest EU, but I may end up having to order all the mounts from them here soon.
Try @Onur; he has the story on the rear mounts. Check out his NLA parts thread.
IIRC, they are available, but listed for another model.
Febest EU just said that they shipped everything, including the rear mounts. Should be here Monday, fingers crossed. I'll post up pics of what shows up.
Anyone have the complete OEM body mount part #s along with qty needed handy including the JDM rear mount referenced above? Thx.
I used the Febest numbers listed there, not sure about the HDJ part number tho
80-Series body/frame mount bushings, part numbers, from front to back (Febest calls them "FRAME CUSHION"):
(1-front of frame)
2 x 52201 60021 (Febest TSB080)
(2-under front seat feet)
2 x 52203 60042 (Febest TSB081)
2 x 52204 60042 (Febest TSB082)
(3-under rear seat feet) and (4-under rear seat)
4 x 52205 60010 (Febest TSB083),
4 x 52206 60010 (Febest TSB084)
(5-outboard of rear springs, no through bolt here?)
2 x 52209 60050 (Febest TSB085)
(6-rear of frame)
1 x 52241 60030 (R) (discontinued part) (Febest TSB086)
1 x 52242 60020 (L) (discontinued part) (Febest TSB087)
$280 total for the set (free ship) from Automotive Aftermarket Parts Supplier | Febest Europe Distribution, as of October 2019.
as you see for the last 2 parts the OEM are not available anymore unfortunately....
Cleaned it up a bit and added the engine mounts for convenience:
Front engine mount212361-17011
Rear engine mount112371-66030
(1-front of frame)
2 x 52201-60021
2 x 52203-60042
2 x 52204-60042
4 x 52205-60010
4 x 52206-60010
2 x 52209-60050
Anyone have the HDJ81 part #s handy that's interchangeable with the FZJ80?
(6-rear of frame)
1 x 52241-60030 (R) (discontinued part) HDJ81?
1 x 52242-60020 (L) (discontinued part) HDJ81?
So far, $774 shipped to door.
The above post should be added to the sticky 80 series faq.....
Calling @Romer or @nuclearlemon
Shipping was fast, and to my untrained eye that looks like the right part! Febest EU wins!
Got the new mounts put in today. Had to buy a new jack to get the body up high enough, even with my sketchy stack of 2x4s as a spacer. Significant reduction in road noise and a moderate reduction in vibrations in the cab.
