Well as I said earlier in this post (from almost 2 years ago), "We will see".
Tonight was the night 'We saw'.
Mrs. Flintknapper calls me right about dark and tells me the Lexus started "sputtering" and lots of dash lights came on. NO problems with it earlier in the day. I make the 20 minute drive to town and find that the battery has 9.6 volts, jump the vehicle and look at the ScanGuage, alternator is putting out 8.6 volts. Battery is 2 months old.
Looks like I am going to get to use that 'Lifetime Warranty' after all...(not that I want to). Not a fun job. $157.00 to have the vehicle towed to my house outside of town. Time for me to get AAA I think. Second time this year I have had to be towed (previous tow ended up being a stuck thermostat).
So..the debate rages. Do you take your chance on a DENSO reman alternator with a 1 year warranty or go back with the best aftermarket reman you can find (longer warranty).
Dang! I was going to get some of my rifles out tomorrow and do a little shooting. I'll be wrenching instead.
I have a question about voltages. I don't have any warning lights or weird electrical issues but since getting my Scan Guage, it's made me paranoid, haha. Idle RPM, easy. Engine temp, easy. ATF temp, you guys in another thread told me my temps were fine. Now the voltage question. When I turn on my 100, it says 14.0 to 14.2. When it's warmed up, when I drive it's around 13.4-13.5. When the engine is warm, when i'm idle, it sometimes drops to 12.7-13.0. Once I start driving again, it jumps back to 13.4-13.5. Some older threads here and on the 80's forums say it's normal. Some threads say it's not normal and to change the brushes (the bearings are making no noise). What do you guys think?
Have to decide whether I want to pull it out the bottom again or try going out through the top this time.
Trying to remember how this went down - did you rebuild the original unit you took out?
I could not get mine out from the bottom. Top was not too bad, I almost wish I had just started out taking it out that way!
Let me say this, PS pump does not need to come off, nor does the top radiator hose.
I started out underneath and just removed the PS pump bolts and removed the alternator bolt and nut. Once I finally got the connector out (darn!) I could not get her out from underneath, so then I tried out through the side - nope.
So I went up above, pulled the air box, and I think I had to move the coolant reservoir. I will see if I took any pictures.
OEM reman is still best option?
OK, so..... 'round 2'.
Got the replacement Alternator installed.
The exchange could not have been easier (wasn't expecting that). They didn't test the old one, didn't ask any questions, were apologetic about the early failure. I handed them my old one, they ran the receipt through their system, gave me the new one (with receipt) and I was on my way in less than 5 minutes.
So...now that I have removed and installed an alternator both ways (from the top, from the bottom) my opinion is that it is equally difficult either way, just for different reasons. It's not a real 'ball-buster' of a job, but not something you'd ask to do for your Birthday...you know.
Hopefully this one lasts longer than the first one.
Whats the price on the OR Alt?
Yes! I would replace the alternator while you are in there. It sits under the Power Steering pump and is not too easy to remove without making room. Having the fan bracket (shroud?) out would make it easier to do. I replaced mine preventatively when I replaced the PS pump and I'm glad I did. Here is what I bought (in this case for your '98): https://www.rockauto.com/en/moreinfo.php?pk=5777277&cc=1368547&jsn=342Hey all...
I have to replace my fan bracket and I am considering replacing an alternator that shows no signs of weakness... since I am there and its not a fun thing to have die randomly.
Given that there doesnt seem to be a perfect option between the reman's and we see failures on both sides (toyota and the auto part stores) would you recommend preventatively replacing this?
Also... @flintknapper
I am not seeing anything on O'Reilly's website that states Ultima replaces the bearings, brushes and springs. Was that from O'reillys website or a different source?
