Removing steering column clamshells - pull wheel?
Southern Colorado
1993 year - looks like you have to pull the steering wheel to get the lower clamshell off? My clamshells are flopping around on the column (when paired) and I need to find a way to get them properly re-installed. Thanks!
Just Separat the two half's no need to pull the steering wheel. You may need to adjust the tilt up and down.
If there flopping around then the mounts are broken off and you need to replace the clamshells.
