Removing pulley from 77 fj40
Ohio
How do you get the pulley off of a 77 fj40 smog pump?
ToyotaMatt
Factory Focus-Point Mind-Set Approach
Supporting Vendor
GOLD Star
EAST COAST
Website
vintageteqparts.com
you unscrew the big hex nut ......
lefty loosie
if you cant hold the pulley still at the same time ?
u will need a AIR GUN and this welding glove to hold the pulley
why do you need to remove it ?
Believe I see a tab from a lock washer bend over the nut. If so straighten that out before removing the nut. The shaft has a keyway think you will find the two holes in the pulley are threaded. Will need a pulley to get the pulley off the shaft and press it back on when you assemble the pump.
Ohio
The nut is loose but is being held down by something, I will see if there is a tab
Helena MT
air hammer?
ToyotaMatt
Supporting Vendor
GOLD Star
EAST COAST
Website
vintageteqparts.com
