Removed starter, found a lot of gunk inside the flywheel housing
California
1994 Prado kzj78. Has anyone seen this before? I’m thinking a very slow oil leak over time which has gummed up.
I’ve seen some gunk built up in bellhousings, but usually only 1/8-3/16”. That amount is beyond what I could have imagined! I suspect you’re right about the slow oil leak, it could be either engine or transmission oil, or possibly both, mixed with a copious amount of dust and mud. Is the little rubber flywheel inspection cover still present?
The inspection cover looks intact although a bit hardened (unless it’s supposed to be like that). Definitely a couple good globs came out. I still have more cleaning to do but at least this leak looks manageable.
Damn, that's a lot of junk...
Does it smell like gear/atf oil or engine oil? Clutch slipping?
Probably rear seal. Possibly bearing retainer seal (trans). Maybe both.
I should have given it a better sniff before tossing. Clutch is good.
