Those timing covers can be a pita. Lots of small tricks. Make sure the edges sit flat. I took a small hammer and wood block and totally flattened it. Definitely scrape off all gasket. Also when installing do all the bolts torque slightly to allow the cover to completely align. Then make sure to know what the torque specs are for the bolts.
I had to redo this three times to get it right. Such is the learning process. Good luck
I just realized that I don’t know what the torque is for the (10) small 10mm head bolts with the Phillips screw heads. Two of those are the longer ones. The FSM doesn’t provide a torque value and the Toyota bolt specification does provide it (to my knowledge) since there is no marking on the bolts to reference.
