the HB should not move at all on the crank shaft. if it does, there is an issue that needs to be fixed,
worn key
worn key way in crank
worn key/ID of HB
wear on the crankshaft snout
combo of all 4 above
if there is in and out movement, is the HB moving or the entire crankshaft?
I’m not familiar with what the key is. I haven’t seen any detail of that. Is that a small key that inserts into the Timing Gear and protrudes out and inserts into the HB to keep them aligned (from what I’m seeing in the Engine FSM)? If that is the key, what holds it in place (will pulling the HB) affect the Key)?
I don’t believe the Crankshaft is moving in/out; I think there is just a very slight amount of play in/out with the HB on the shaft. There must be some wear somewhere since there is a slight gap between the locking plate/tabs and the Nut. Maybe it just loosened over time to allow the gap, but the Nut isn’t loose.
