On every rear disc writeup I've seen, it's said that depending on the width of the rotors used, longer wheel studs may be needed. If they are needed, it's also said that the axle shafts need to be pulled out a ways to replace the wheel studs. One thing I've noticed though, is that tis is all for FJ40s. Is it necessary to pull the axle shaft out at all on a 60/62 series to change the studs? I'd like to avoid it if at all possible, becuase I don't want to mess around with that extra amount of work.
