removal of manual locking hubs 77fj40
Discussion in '40- & 55-Series Tech' started by mike, Jun 16, 2005.
  1. mike
    mike 82bj42 1st project
    2,660
    28
    Mar 12, 2003
    Toronto,Canada
    I am having trouble removing the #4 allen head screws on the locking hubs. They seam to be stripping as I apply some force to extract them. Any tips on how to remove the damaged screws? Thx inadavance Mike
  2. trainrech
    trainrech
    2,804
    131
    Sep 16, 2004
    Emporia, KS
    Take a hammer and lightly tap the allen wrench into the screws to make sure it is fully seated. Also, soak the crap out of the screws with either Kroil, PB Blaster, or similar product.
    HTH
  3. mike
    2,660
    28
    Mar 12, 2003
    Toronto,Canada
    I tried soaking and hammering, however a few are stripped. What the best way to removed the stripped screws? Thx
  4. Mud Shark Rosey
    Mud Shark Rosey
    363
    17
    Jan 31, 2005
    Ont. Canada
    Hi all, new to mud but have been working on Cruisers for about 10 yrs.
    You can try hammering a torx bit in, or if all else fails drill the heads off and use vise grips to turn them out after the hub is off.
    Good luck!
  5. John Smith
    John Smith In the garage
    4,208
    Media:
    6
    Albums:
    2
    268
    Jun 7, 2004
    Maryland
    Ezout or any reverse drillbit/stripped screw extractor. Sold at your local hw store and even Sears nationwide. Then throw the Warn hubs as far as possible and buy some stock hubs. Cone washers are much more fun to deal with.
  6. mike
    2,660
    28
    Mar 12, 2003
    Toronto,Canada
    Are Warn hubs bad? Why?
    Thx
  7. cruiseroutfit
    cruiseroutfit Supporting Vendor Moderator
    8,821
    6,582
    Jan 9, 2003
    Utah
    No, Warn hubs are good units, however they don't seem to be nearly as "maintainance" free as the OEM Aisin units.
    You might try and find a pair of Aisin hubs (if you are still running a drum brake axle, Warn/Superwinch/Selectros are really your only choice)
