I put it 35 but it becomes tough and not smooth at all. So i guess better to put it at 32 front and rear
We typically would recommend going by the PSI indicated on the door sill to determine the optimum inflation pressure. Because you are using an alternative size rather than the OE size of P275/70R16 we would need to convert the maximum load to determine the recommended PSI for the LT fitment. The maximum load for the OE size at the recommended pressure of 32 PSI would be 2,450. We divide that by 1.1 and it gives us 2,255lbs which equates to 45 PSI for your current fitment. This would be the recommended inflation pressure and it will give you a total carrying capacity of 9000lbs.
FYI: The pressure indicated on the sidewall of the tire gives you the maximum inflation pressure for your Load Range C (6ply) tire. This pressure shouldn't be exceeded and is only to be used if you need to carry a maximum load of 9,880lbs.
