Recommendations on Rechargeable LED Tactical Flashlights
+1 for the Fenix PD35. I've had mine for years and absolutely love it. It's compact, durable (have dropped it from 10 + feet onto rock cave floor), and oh so bright. Multiple brightness settings extends the battery life as you only have to use as much light as you need. I often keep it clipped to the inside of my pocket like many people do with their pocket knives, which keeps it close at hand. I have a small dual 18650 charger, but find I only need to charge the battery twice a year or so with moderate use. I also have a small frosted plastic diffuser tip that snaps on the end of it and spreads out the light kind of like a lantern - useful at times. You can't go wrong with this light. Photo with diffuser.
18650 battery quality is very difficult to find, I just trow two ultrafire away:
-charger says full after 10 minutes but output is very low, light is very dim.
I have one good (but expensive 15$ per piece) 3400mAh EQ EDEN panasonic Li-ion and same quality seems
Enerpower NCR18650B 7A PCB Button-Top Li-Ion
One movie shows how a battery pack is filled with sand!
I have one of those big led lights but they work far better with a separate 12v 7amp battery and many problems can happen from faulty contact in the screw on part: flickering, trouble.
If you test with a paperclip you can find where the bad contact is has had me puzzeld a few times, clean thread but still bad contact.
I use a headlamp princeton tec APEX that is used on mount Everest (same as repairing a cruiser) princeton tec APEX | eBay
