mini update
well,
since I am waiting on my new toyota rockers to get here, (along with some little bendy twisty water hoses that i would never find locally)
i went ahead and did some work on my timing cover. when i disassembled the engine i noticed there was some scarring where the oil pump gears ride on the machined front surface of the cover. hopefully, this was at least in part what was causing my low start up oil pressure.
anyways, rather than buy a new one, cause the backside has no chain wear at all, i decided i would machine the oil pump surface flat again. hopefully this will give me a nice seal there and my engine wont loose prime. additionally, it will clean up that bearing surface for the new oil pump.
I already examined what impact this will have on other components. the only thing that it will effect is the splined drive for the inner oil pump gear. but the splines are so long, that moving the oil pump gear down the splines a couple thousandths of an inch wont matter. and even if it did, i could just machine whatever i take off the front of the case off the back of the splined drive and it would be back to riding where it was anyway.
(if none of this is making sense, i will post some pictures tonight when i get home)
well, i went ahead and trued up the bridgeport last night. then fired it up with a fly cutter and got to cuttin'. turns out the front oil pump surface of the timing cover had about .0015" runout across the face from the factory. (i measured the unworn bolt hole areas outside the oil pump seal). So i took that much off to flatten it out and true it up with the rear mounting surface that bolts to the block. Then to get the scratches out, I ended taking off another .0015". so all in all .003". which is not bad.
I'll attach finished pics of what it looks like tonight when i get home.
