- Thread starter
- #381
With help of Rudi (bj40green) whom I wish to thank, solved my problem with the Fuel Control Relay that works with an Edic motor, converting it to work with a VSV on a 12HT. The following is a guide to achieving this, and the input from Rudi.
Hi Rudi,
I am running a HJ47 1983 model super glow wiring loom. I have shorted using the current wires with 2 12ht glow plug relays and the 12ht Pre Heat Timer.
I have installed the low pressure oil switch into the 12HT engine so every thing will work with the HJ47 FCR except of coarse the 4 wires going to the FCM (edic) is not on a 12HT engine.
I am trying to understand these 4 wires. "M" acts as power circuit but terminates to earth if the low oil pressure switch does open within so many seconds. I thought I read some where that connecting "M" to the VSV and a earth wire, combining the (joining) the "Y" & "R" together you can create power running onto the VSV on turning the ignition to "ON".
I believe "B" supplies power to the FCR via a FL from the battery all the time whether the ignition is turned on or not.
I am trying to incorporate the low pressure oil sensor into the system as protection which should the oil pressure not come up stops the 12volt feed to the VSV.
Your electrical wizardry skills would be greatfully appreciated.
(Rudi said)
"M" has nothing to do with the OPS. When the power stops to the coil of the bottom right relay, the relay falls back to the rest position causing a short over the EDIC motor. This is done to let the motor stop immediately ( same principle as the wiper motor). In other words there is no run out or after run on the motor.
Connect OI and D together to one terminal on the VSV and ground to the other and it should work.
BUT........ when the center relay (in the diagram) falls back from "OI (start)" to "D (run)" (the left relay is in the D position) there will be a fraction of a second no power to the VSV. Try it.
That round thing with 4 wires is the position sensor and stops the power to the motor when a position is reached.
Rudi
Hi Rudi,
(Rudi said)
Rudi
